How do I get into fastboot mode with no working power button? I need to return to stock so I can send this puppy back and if I turn the phone off I wont be able to get it back on. Help thanks.
oh you need this my friend its great it will root,un lock your gnexus. it can flash stock back to your phone or lock your boot loader step by step it will walk you through by 1 if you see your serial number or 2 as no
then give you options if no.
Its will download the SDK files if you need them and drivers as i said it will unlock or lock your boot loader,root or un root, CDMA or GSM makes back ups it uses command prompt for you so you do not have to manually use fastboot commands in a net shell enjoy.
