Mine does the same thing; I have no idea why. I just use /mnt/extSdCard/Install for all sources; this leverages my external SD card space and I always format internal storage when I change ROMs/rebuild anyway.
Which means CWM is behind the power-curve!
Does CWM compress?
So that's a 'no'.it allows access to all the sub folders on /sdcard ill tell you that![]()
