Helenoftroy08
I ordered my Galaxy Note 2 on the 17th from Best Buy, and it shipped around 2:30 that afternoon. I was soooooooooo looking forward to rooting it I REALLY hope that it doesn't come with the exploit already patched!
I really doubt it will. Those phones are sitting in a warehouse all packaged up for weeks before they're sent out. Just be careful of when you're activating it and it says there's an update.
Not to spoil the fun, but I find that this thing performs so well that rooting is less of a necessity than a few of my prior phones. You are, of course, going to disable other software from taking advantage of the exploit after rooting, right?
Hi Puppa. I selected disable exploit if thats what u are referring too?
Once you root, how and where do you select disable update? Just curious as I would like to be able to root.
