Root [Verizon] urgent! problems midway through root
so i started doing a root on my phone downloaded odin and a few kernels and put my phone into download mode. my phone is a verizon sch-i545 samsung galaxy s4. As i tried opening one of the files, which was .tar so i downloaded winzip to open it. every time i click the file it dissapears after less than a second. after fiddling around for a bit i was able to get to a zip 7 window but when i try to open the lone file (boot.img) the following error message occurs: error-internal processing iso image :confused:
I also just tried with the other kernel (there are 2) and the same thing happened
please help! is there anyway i can view this file? if not is there a way to exit download mode? I have not downloaded anything it just says on my screen downloading...do not turn off the target!!! with some small official text in the top left corner including odin mode. Thank you so much:)
Look in xda forum. Others have had the same problem. I think you do a battery pull, boot back into download mode again but instead of hitting the volume up button to get into download hit down to reboot normally. This should get the phone back to its normal state.
Welcome medphratalon:)
What root method are you following? The reason I ask, is although I have an samsung S3, the method will vary, and I want to check out the method you are using:)
Perhaps we can sort this out ;)
I just picked the first one that came up...then I did a little searching and came upon another I gave up after about 2 hours of not being able to open the files. They were both pretty similar, using odin and a few kernels. Apparently my build number isnt correct for that root, so maybe I will try again in a few days
I'll almost bet you're on the me7 version and not the MDK. There is only one way to root your phone right now. Go to the XDA forum and search for "how to root the vralme7" galaxy s4. If you're planning on installing a custom recovery, its not possible yet. There is a Dev working on a method as I'm typing this but as of now you're SOL! I'm gonna go see if I can find that post for you and I'll be right back with the link.
http://forum.xda-developers.com/showthread.php?t=2380325 this is the root method you need if you're running build vrualme7
