I recently brought my gs3 to south korea with me and bought sim here (KT) so that i could use it. at first, I could call & text with very very slow data. But soon I found out my phone force closes the call app and doesn't allow me to receive a call, so i flashed newer version of my Rom, pacman 4.2.2 5/24/13. However, since then my phone doesn't have any network. when i check the phone info, it always fail to get ping IpAddr. It does NOT let me to pick GSM mode anymore either (when i select GSM, it changes back to LTE/GSM/CDMA auto or something that I select that is not something GSM). I still have IMEI. I've tried flashing back to stock rom but no luck =/. I cannot take it back to verizon store since I'm in Korea, do you guys have any suggestions how to fix this?
my current phone status is:
android version: 4.2.2
Baseband version: I535VRBMB1
kernel version: 3.4.41 -cyanogenmod-g2937b16
Build number pac_d2vzw-userdebugg 4.2.2
Phone info
Ping IpAddr: Fail: IP addr not reachable
Ping Hostname(www.google.com): Pass
HTTP Client test: Pass
Signal Strength: 2147483647 dBm 255 asu (GREAT SIGNAL ISN'T IT!?)
neighboring CID: unknown
Roaming: Not roaming
GSM service: Emergency calls only
GPRS service: Disconnected
Network type: unknown
Message waiting: false
Call redirect: false
Call status: Idle
Radio resets: 0
Data attempts: 0
Data successes: 0
GSM disconnects: =======DATA======
I will provide anything you need in order to fix this. Please, help me get through this!
Phone info
Call status: Idle
Radio resets: 0
Data attempts: 0
Data successes: 0
