Androidcurious
Does this mean the device has been rooted?
Thanks, guys.
Thanks, guys.
What device are you referring to and where are you seeing this?
I moved this to the note 3 section where other users can chime in.
It typically means the software has been modified - it could be rooted and running a custom ROM or the stock ROM rooted
Hi AndroidCurious!
Since you're already more than halfway there, why not try a custom ROM like Hyperdrive and see what the ROM craze is all about? It's got all the great features of Android and the Note 3, while eliminating all the bloatware and limitations of the stock OS. I never thought I'd end up rooting and ROMming my Note 3 since it was so versatile to begin with... but I guess you can't keep a good geek down
The ROM you select has to be for the Note 3 version and on your specific carrier. Since I don't know what carrier you're with, I can't really make a more specific recommendation.
If you still want to go back to stock, though, Dynomot or someone else in the All Things Root section can certainly help you get there.
Okay, you have my attention.
My GN3 is on VZW. Now, I only use Macs. Is that an obsticle in any way?
What I'm interested in is running vanilla Android, killing bloatware but keeping Samsung's camera features. Does such a creature exist?
Yeah: Scott Breen, the developer of Hyperdrive ROM, kept all the best of the stock OS, and took out the garbage. He's up to RLS 8 which is KitKat 4.4.3... although it's tricky and requires a few more steps than RLS 7 which is 4.4.2.
Yes: having a Mac is an obstacle... but not catastrophic. You can read up on the features and tweaks of Hyperdrive 8 here:
★[ROM][MAY 11][4.4.2] Hyperdrive KK RLS8 ║║ Hyperdrive Tweaks - OTA - HUB - Files & Much More!║ GS5 UI ║★ - xda-developers
Impressed yet?![]()
. We can try our best to walk you through the install process.
