Just got my X today and I'm having a problem that is driving me nuts. When someone calls me, before the ringtone, a female voice announces "Verizon Wireless!," and then it proceeds to the ring.
It's obnoxious as hell. Anyone know how to turn that "feature" off?
Menu, settings, call settings, scroll down to "caller id read out" change it to "ring only".
Ack. None of this stuff has fixed it. It also gives me the "Verizon Wireless" every time I make a call on my end, before it actually goes through. Anyone? Bueller?
In settings/sound & display if you scroll toward the bottom there was something like "play sound on call connect" did you check to see if that was checked? there is several others in there as well so maybe some of those are selected as well.
Most excellent! It worked!Goto Settings > Sound & Display Settings > Roaming Tone .
If you turn that on, it tells you what network you are on when you dial. Hence the "Verizon Wireless"
Hope that helps![]()
