Hi all, I've been trying to fix my Xperia Play for a week now with no success. I installed Launcher Pro and tried to change the wallpaper. Launcher Pro hung. Now the unlock screen doesn't work. If I connect via USB I can sometimes drop the notification bar, but choosing any of the programs causes them to hang. I do not have USB debugging enabled to remove the launcher or install a new one. My Play is still showing my WIFI network, and getting new notifications, but I cannot do anything with it. Is it completely messed up? I've tried everything I can think of:
SE PC Companion - Update - Asks for MTP mode - cannot do that because it doesn't show up in the notification bar.
SE PC Companion - Repair - Tries to update but then says that no update is available.
Android Injector - Reports that USB debugging is not enabled - cannot install new APK (tried to install a new launcher).
Install new launcher via Android Market - I do not have 3G data (disabled in settings as well). The new launcher never downloads.
Root/flash new kernel - I don't want to pay to get it unlocked - I also cannot get into the settings to get the IMEI number.
Any other ideas folks? It's crazy to me that a simple software issue can completely mess up my phone.
Note - I did get this problem once before, that time I was able to get into the settings via the notification bar, I was then able to get the default launcher set as the default launcher. Once that was done, I was able to clear the cache on Launcher Pro, which solved the frozen lockscreen problem. Is there any way that I can clear the cache without having access to the settings on the phone or having USB debugging enabled?
Thanks,
Anna
Thanks,
Anna
