Maybe a dumb question, but I recently rooted my Nexus and when I try downloading an .apk it automatically changes into a .zip and sends me to CWM to flash it instead of just installing it like normal. Am I missing something or something I need to change?
The host file is a zip file, some hosts will not support hosting .apk files so whoever is putting it up is just renaming it before uploading it, if you rename it as VS suggest you should be able to install it fine. After you rename it the icon should change to the app's icon.
