MiXoLoGiSt
I went to Best Buy and they just got in the Demo model of the Note 2 for Verizon.
I just wanted to let you know of some changes I noticed compared to other Note 2s.
First thing is the digital clock widget is gone. This is the clean simple clock widget you see just the time and date on. This was kind of disappointing to me.
Second thing is there is no wifi toggle on the top of the notifications. Instead it has an ongoing notification which can kill battery life faster.
The third thing I want to note (no pun intended) is that Verizon's version DOES in fact have the multitasking ready to go. You won't have to wait for an update for this feature.
I wish I could have tested reception but Best Buy doesn't activate any of their demo phones.
The fact is... even in the LA-metro area T-Mobile is iffy and unreliable. Add the fact that I do take long road trips and use data the entire way. T-Mobile won't be ready for consideration for 2 years. I just needed to vent. They were my first carrier when I started with the Sidekick II as my first cell phone. I went to AT&T from there and then ultimately Verizon. Each was better than the previous carrier in service.
Or if you download a launcher I'm sure you can add a wifi toggle switch
