criscross79
I'm not sure if it's normal or not, but when I use Google navigator my phone gets really hot!
I use the car dock a lot and it doesn't matter whether i have it plugged in or running on battery, it still gets hot. I have seen it as high as 130 degrees before the phone eventually locks up and then shuts down. The only solution i have found is to turn the defroster on high and blast it with cold air.
I have also noticed the heat when I have used navigation hand held.
It usually takes less then 5 minutes to start hearing up
Is this typical?
Chris
Is this typical?
Chris
