Help VERY IMPORTANT MATTER
I have a lenovo a3300 running android kitkat bla bla.. My probem is whenever I upload files, I can only choose from CAMERA, CAM CORDER & GALLERY (SEE IMAGE). My question is, is there a known fix for this problem? I can't upload important documents because of this. Thanks for the future replies my good sirs :)
Tnx for the reply sir!
No. I'm trying upload my resume to my jobstreet acct. But regardless of where I upload my files the options appearing are only what you see in the photo posted above. So if I want to upload .txt or .pdf files, I can't. Beacause I can only choose the files from what you can see on the photo above, and that means only .jpeg or whatever img files p!ease help T_T
I see. So the files you want to upload exist on your device and trying to upload them to your jobstreet account only results in the pictured options.
With that being said, are you accessing your jobstreet account via your device? And when at the jobstreet account, it gives you an option to "upload a file" and the pictured options are the only options?
I realize I may have repeated what you said, but it helps me understand it better.
Perhaps you need to remove the default upload option?
I think it's in "manage applications" then the settings , then remove defaults.
Yes thank you, ive done what you just said but same problems still exist. I can always just use my pc to upload documents but you will never know when you will have to use portable devices to upload documents, thats why im trying to fix this problem wahaha
I had a similar issue earlier this year that was solved by installing a better file mgr. I'm currently using Es File manager from Google Play. After installation, I rebooted and a "documents" option now appeared below the camera/gallery buttons in which I could use my filer to select any kind of file.
Here: https://play.google.com/store/apps/details?id=com.estrongs.android.pop
Do you think maybe the problem is the file manager? I already have Es file manager installed, but my device also has a built in file manager. I think ill temporarily delete my es file manager and see if the problem still persist. Thanks :)
