I was messing around w/ apps/etc on my Droid like usual. All of the sudden something seems to have gone wrong w/ it. I don't know exactly what I was doing when this happened, but a lot of things have changed. The first thing I noticed was my lock pattern screen (which I keep turned on) was off. And I saw the lock screen that is circular and has the date and time in the middle of the screen. I have heard discussion about the circular lock screen, but never personally had it. So I immediately was confused when my Droid screen turned on and I saw this. Now my Droid isn't able to save some settings properly. I keep going to Settings and turn on lock pattern screen and check it, when I leave the settings and go back, it is back to being unchecked. Also my screen timeout happens after only a few seconds. I had it set to a minute and now it times out very quickly. I went to settings to change this and that setting does not save properly either. Then, out of nowhere, all my apps on the home screen just disappeared. It's like my Droid is losing it's ability to save user data. I have no idea what brought this on, and need help please... Running Sholes ROM smoked glass (I think) with regular home screen (not launcher). running at 600 MHz.
