Help Very weird malfunction after screen replacement - hardware or software?
NoebNoeb
Just as i was about to buy a case for my Sensation i dropped it on the floor, completely cracking the screen.
Then i went to a repair shop and got a new screen installed, but something very weird has happened:
When i turn on the phone and the lock screen appear, the bottom left corner of the screen (the first 3 icons from the left and down from there) is completely unresponsive. However, after waiting for 10-15 seconds the entire screen works as normal. After that everything runs smoothely, i can use the bottom part of the display for writing messages and such.
The lock screen icon on the right is still responsive all the time, but if i use to open the app, the same part of the screen will still be unresponsive for 10-15 seconds. This includes the bottom four buttons.
So do you have any idea was is causing this 10-15 secound delay in activation of the lower left corner of screen? I have a three month warranty from the repair shop, so i can easily go back and get it fixed for free.
Thanks in advance for any help.
