Help Viber issue
janathan
I have noticed for the last 2 months that when i long press any pic OR want to share any pic from facebook.....in the list of apps that appears to share thru (whatsapp, messaging, skype, instagram etc etc) viber is missing.
The only way i can send a pic thru viber is to go thru viber then find the photo in the device then send. which is annoying.
Somehow viber disappeared from the "share thru" app list.
I deleted viber and installed again but no change.
any help?
thanks
Same problem here, i think it's an app issue so you would have better luck emailing viber support. They didn't reply though when I emailed. It is annoying that I can't share pictures directly from gallery or file explorer. It started when I updated the app to the new version that has stickers. I'm on Jellybean FK23.
Have you got a backup of an earlier version using titanium backup etc?
Note: I never update unless there is a need to. I have seen far too many apps that become crappy after an "upgrade".
