Help Vibrant Screen Locks During Calls
When ever I make an outgoing call the screen goes black and usually does not turn back on. However if someone else ends the call the screen will come alive again. But if the call goes to voicemail or something is screen will stay locked out and the only way to fix it is to power cycle the call. It is quite annoying.
Is it possible that my case is blocking the proximity sensor? What I would really like to do is just disable screenlock during phonecalls.
Does anyone have any similar problems or any suggestions?
