Help Vibrant texting question
my vibrant kinda vibrates just a little and once, i want to know how to fix that?
;also, can i change each homescreen wallpaper? so they are not the same? and the locked wallpaper can that be different too?
Vibrates when you touch a text key? You can turn that off or adjust the vibration level. Go to settings>locale and text> pick your keyboard and go into it >vibrate on keypress.
And no , you can change each homescreen wallpaper that i know of.
no, it doesnt vibrate when i get a text and i have it set to, but it still doesnt.
Dont know what text app you are using but if it is the stock, it should work if it is checked. But i havent used that one since the 2nd week since July so not sure. Handcent SMS has a lot more options.
I have the same issue. When I get a text, it's just a short jolt. It's supposed to be a prolonged buzz. I posted a while ago but I couldn't get any answers.
