chrisjv3393
Does anyone else have this problem? The phone wont vibrate wen set To vibrate for Wen u Recieve a notification..
do you have it fixed in the settings? like say you receive a message on the messaging app, you have to change your settings to always vibrate.
No problem here, even with MP3 ringtone. But I'm also using stock notification sounds...
I have set to always vibrate for phone ringtone and SMS/mms notification...and both my email notifications are set to tone only...everything works as set.
chrisjv, are you using a downloaded sound or stock?
Matt
just thinking that a non-stock ring/notification might somehow mess up settings... <shrug>
just had a thought...do you have your phone set for haptic feedback? you know, when you hit buttons or select things, you get a short buzz. if its set to on and you're not getting those, then maybe vibrate motor is stuck or dead...
Matt
