AndroidNEW-B
Vibrate quit working on my Hero yesterday, anyone else have this problim?
Ill try that, thanks.Yes, I posted the issue last week and several others have beginning months ago.
We've downloaded Sound Manager and have set the notification options through that program, which solved the problem. This appears to have started to happen since HTC launched an update to the phones which I ran manually.
Hope this helps.
any other ideas? or is it back to the sprint store for me?
Vibrate died on my phone about 2 days after installing 2.1. I'm sure it was a coincidence.
Sprint will replace the phone, but only with a refurb. Having had a huge problem with a previous refurb from Sprint about 5 years ago, I will just keep my non-vibrating phone until I get either an Evo or a Droid X.
I did that, but thanks for trying.After opening Sound Manager, hit menu, go to vibrate settings, and make sure you've selected "vibrate whenever possible."
That's how I solved my issue. Sorry if that doesn't work.
So, did you bother doing a hard reset on the phone before you supplied yourself with a refurbished P.O.S.?
Did you pursue sound management programs? Just curious...
