Help vibrate too soft
dsandb
when in vibrate mode, and in a case clipped to my belt, i do not feel the vibration for incoming calls or text messages. is there a way to increase the vibration, or is there a particular case with belt clip that will work better so i can better feel the vibration. i never had this problem with my old plain cell phone.
There's an app called "Contact Vibrate" that allows you to make custom vibrations for each or all of your contacts. You could try to make a longer vibration that will be more noticeable.
No way's to just increase the actual feeling of the vibration, just the length. I recommend trying that out and seeing if it helps at all.
There's an app called "Contact Vibrate" that allows you to make custom vibrations for each or all of your contacts. You could try to make a longer vibration....
[Insert dirty joke here]
Anway I have the same issue. Just lengthening the vibration won't help me detect the vibration. If anyone has a solution please add!
