Help vibrates on call connect
robin man
hi, just joined the forum. i have a htc desire hd. only one question, wil i make a call, the phone will do a quick vibrate when the number ive called connects.
is this normal. thanks for your help.
That's a setting in developer options on my phone so probably the same on yours. Its for testing purposes if I'm not mistaken.
Find developer option in the settings menu and it'll probably have that checked.
thanks blackflag4, its not a great problem, once you get used to the thing doing it.. had a look though phone, cant see the developer option in settings. will look again.. thanks for your help..
If I remember correctly, I think I heard someone say the developer options were hidden on some phones.
Try this:
1.Launch Settings from the application launcher
2.Select About Phone
3.Scroll down and locate the Build Number entry
4.Tap on the entry 7 times
