Help Vibration droid x
umfan6
Just curious if you have haptic feedback on when you touch home screen icons are they suppose to vibrate , because mine don't and was wondering is this how it is suppose to be or just the phone. When i do the pattern unlock i feel it vibrate but when i touch icons on my home screen they do not???????
this is a setting that you can change in the settings. or it is on my droid at least
I don't think you can for icons.
I think you can only make selections use hipatic feedback, could be wrong.
Even with Haptic Feedback on, it won't vibrate from just touching an icon on the homescreen. It will vibrate if you touch and hold, letting you know you can delete or move it. Also, with Haptic Feedback on, holding the dedicated camera button causes a vibration when the camera has successfully started.
Hope this helps!
