Help Vibration intensity
VGPod36
My Mother just bought a brand new Galaxy S3 from Telus (Canada) and the vibration intensity is not as high as my S3, that I bought at launch, with Rogers. We went through the options, and hers is set to max, same as mine. We just can't figure it out...
Thanks! :)
Its also possible they adjusted it down after release due to them failing earlier than expected, or for more battery life, or any number of other reasons.
There may be root options for increasing it, but seeing as its not your device that may not be an option
Mine will sometimes have a good strong vibration and then others it almost does nothing. I've had it in my pocket and got a text and never felt anything. I miss the good old days of a phone I had about 10 years ago that when it vibrated it was just short of a taser jolt.
