vibration re-setting automatically
thehulk20
Member
i set the vibration to "only in silent mode". but, when i make or recieve a call it automatically switches to "always" on its own.
any ideas?
well...i figured out. it was a vibrate app that i had installed that was causing the issue. i found another one to use, which helps with the low level vibration on the phone. it allows you to customize the vibration rate and length.
