Help vibration when texting
jo sharp
Hi.
I have just got a HTC Wildfire and it vibrates when texting. I can't seem to find where to disable the vibration. Any idea?
Thanks, Jo:confused:
Welcome to Android Forums!
You are talking about haptic feedback. To turn that off, go to menu>settings>sound and scroll to the bottom of the page. Un-check the box next to haptic feedback. If you are using a keyboard other than the stock Android keyboard you may have to disable those settings as well. Let us know if this works for you.
