Help Video and Media Converting?
AlbinLee
Hello All,
I have had my Razr Maxx for about a month now, and so far am loving it. Coming from a rooted Droid 2, this thing is amazing. I miss the physical keyboard, and would have got the Droid 4 if not for the atrocious screen. This phone is so fast I am reluctant to root and overclock it for now.
My question is can someone please provide a step by step method for putting DVD quality media on my Razr? I have TV collections saved to my computer, like Eastbound, Deadwood, and Sunny in Philly. I would like to convert these files and put them on my phone to watch when I am away from the computer, but so far it has been a pain in the ass! :( I think the files are in .avi format, or maybe another type.
If I connect the Droid in PC Mode, my computer allows me to drag and drop files onto the phone, offering to convert them into a watchable form. This takes about an hour per episode, and fails to complete when I try (usually about halfway through). This never used to happen with the Droid 2.
My other choice is to convert the files manually, and put them on the phone in mass storage mode. Please tell me a program, and steps to do this. I tried Quick Media converter but it took 12 hours to convert a 2 hour film. And when I tried to convert a 1 gb DVD into Mp4 (x264) in 1080p, it was almost 10 gb when completed! :eek: And my phone wouldn't accept that large of a file, even in USB mass storage mode.
Please, any help would be appreciated. Thanks!
-Albin
I have used Handbrake and it works pretty good. They have different presets for different devices. Do a google search on Handbrake and you will find it. Plus it has a nice batch processing utility and you can convert as many movies as you want and do it at night when youre sleeping. I have converted many movies to my Motorola Xoom and its worked everytime. Let me know if that helps.
okay I will take a look at handbrake thanks. does anyone know specifics as far as what file format I should choose to convert to? include file format and resolution please
I have used Handbrake and it works pretty good. They have different presets for different presets. Do a google search on Handbrake and you will find it. Plus it has a nice batch processing utility and you can convert as many movies as you want and do it at night when youre sleeping. I have converted many movies to my Motorola Xoom and its worked everytime. Let me know if that helps.
+1 for Handbrake. It may not be the fastest option out there, but the price is right and I have no complaints about the output.
~Gary
If you use Handbrake it will chose the format automatically for you. I think there are ways to tweak the video image settings as well but I leave mine to default as its good enough for me.
I use an app called MX Player, seems like it has a good set of codec which comes with it and it has frequent updates, even the free version, which is what I use.
I generally take my vid's from pc and just drag and drop into the external memory card, in whichever format it is: mk4, avi, mpg, wmv, flv, mpa, rmvb, mp4, rm and they all seem to work for me!
