Help Video/Audio help
Flablitz
I have 2 questions that I cant figure out. I am usnig the default media playe called "Video Player"
1) Can I make the video display in full screen instead of black borders all the way around?
2) When I play a video file it is hard to hear. I have media volume all the way up is there another way to increase it or have it on speakerphone for louder sound?
Please help if ya can, other than that Im pleased with the phone.
Stats of file tried playing.
Code:
Video
Format                           : MPEG-4 Visual
Format profile                   : Simple@L3
Format settings, BVOP            : No
Format settings, QPel            : No
Format settings, GMC             : No warppoints
Format settings, Matrix          : Default (H.263)
Codec ID                         : 20
Duration                         : 1h 15mn
Bit rate mode                    : Constant
Bit rate                         : 512 Kbps
Width                            : 640 pixels
Height                           : 480 pixels
Display aspect ratio             : 4:3
Frame rate mode                  : Constant
Frame rate                       : 23.976 fps
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.070
Stream size                      : 278 MiB (73%)
Writing library                  : ZJMedia MPEG Encoder
Language                         : English
Audio
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format version                   : Version 4
Format profile                   : LC
Format settings, SBR             : No
Codec ID                         : 40
Duration                         : 1h 15mn
Bit rate                         : 188 Kbps
Nominal bit rate                 : 128 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Sampling rate                    : 48.0 KHz
Stream size                      : 101 MiB (27%)
Language                         : English
