Help Video quality
kujodogg
There are a few video converts programs I found in these posts but have failed to get to work properly. Right now I am using format factory but an willing to try another. What does it take to get blue rays or dvds close to the quality of the avatar movie that came with the phone. Any help is appreciated. But setting specifics would really help cause I really haven't done a lot of converting before
I use either handbrake or videora
Can you use Videroa without using any I-Crap stuff. The instructions says after the convert it sends it to ITunes then you can download it to your Ipod. Dont have an Ipod. Dont have Itunes.Dont Want them.
