Video settings
Captain01
Member
Let's say that someone wanted to rip or convert movies from a DVD to put on their Photon. What settings would they want to use? Thanks for the help.
What size should I be using to make sure I use all the screen? I'm using a program where you can specify which device you are ripping for and the Photon isn't listed. Is there another phone that I can select that will work for the Photon?
I'd imagine you could use any of the Verizon Motorola devices, but I'm not positive.
Which Android phones are listed?
The Photon resolution is 960 X 540.
The HTC EVO 3D uses the same resolution. Does your program allow you to just set the resolution?
I use DVD Catalyst 4. It does a very good job, has most phones preloaded and allows you to set your own parameters.
Thanks. I was able to download the Evo 3D profile. Gonna try it tonight. We'll see how well it works.
