Root Video! Updated Rooting -keep data & common rooting problems
kraisydave
First, thanks to Android Forums and all the people here as you have helped me a lot. I am not a dev, but wanted to give back so I made these videos in hopes to help out.
One is on rooting without deleting you data while keeping the current updates from Verizon. The other is common problems people run into while rooting. If you check out my youtube channel there are more vids on backup and running ROMs under Android Tips. If you have a vid suggestion let me know and I will make it. Thanks....
Updated Rooting Method
Droid - 2012 Rooting Update keep Data and Apps by: KDtech.org - YouTube
Common Rooting Problems
Droid Charge - Android Rooting Problems Discussed by: KDtech.org - YouTube
Dave
