When I view web pages its quite a few is there an easier way to get to my home screen than pressing backup all the time passing all the pages I've seen before I get back to the beginning, thanks
Thanks for that but when I click back onto internet I'm back where I started with the last page I was onClick the home button?...![]()
There is no need to do that. I suspect the message you had was about the maximum number of windows open. If you get that just press menu and select windows, then close any you are no longer using by clicking the cross in the top right corner.I used to use the home button and then the Internet widget to re-open the net, but I found that eventually links on web pages wouldn't open and I got a message " maximum number of pages are opened " ( or something similar ). Using the back button to close each page until I got back to my home screen sorted it.
