1ceb0x
Member
So apart from being a great rom (scored 4.75 on linkpack) this ROM has some really nasty issues that i can't stand them. I'm just starting this thread to make sure is not just me. If it's me, I will reflash. But if you guys have the same issues, we should try to add bugs we found, and then make a shout to the villain team.
So, until now i have these bugs:
MINOR:
- when the screen timeout is set at 15 and the screen goes black, imediatelly, click on home. You will make the phone alive without the lockscreen.
- when in navigator (loading your location please wait) and the screen goes idle, and you go back, the navigator is going in the background.
- 2 contacts with similar names (i.e Gabi, Gabita) have only 1 photo instead of its own. If Gabi has 1 photo, Gabita which default had own photo, the two contacts will share the same photo.
- in the default music app, you will see sometimes, 2 play icons on 2 different tracks.
Now, the nasty part kicks in:
- [KNOWN] - The GPS is not working. Tried everything (disable usb debuging, disable mock locations, enable gps locations). The GPS is not working and period. Someone stated that if you reflash your rom with the GPS ON (i think that it's not possible that the gps will stay on when you erase all data) the gps will be good to go on the first boot.
So, is it just me? Should i reflash? Do you guys experienced some of these stated issues?
If so, post your bugs.
MINOR:
