How do you exactly install themes on VillainRom 12? I already have the rom installed but I have no idea how to install a theme...And do I have to wipe my phone AGAIN to install it, cause if so, I don't think I wanna go through the process again...
Sorry for so many questions but..
Does dalvik wipe wipe anything noticeable and wats an android backup, dont recall seeing it last time... and partial wipe and flash = ?
Wiping the dalvik cache won't have any noticeable effects other than your next boot being a bit slow as the cache is rebuilt. Same goes for wiping the normal cache. (An option in the more recent recovery images).
And before you put villain on you did a backup, right? That's known as a nandroid or nand backup, if done through the recovery menu its self. If you used ROM manager to do it, it would just refer to it as backing up the current firmware. Do the same thing before flashing the theme.
