Root villian updater help
snox187
lovin all the flashing and new roms , villian 10.1 great but cant make calls ,want to use villain updater , do i download update for call fix onto laptop or do it over phone . had quick search on this but still no wiser , any clear advice on using and applying call fix update would be great
thx tojjer , job a good un , of all the roms i have tried this is the one that has got me interested , lets see what the next 24 hours bring
You can do it using only the phone. Let the OTA updater download it and it will give you the option for it to do it for you.
Doing it manually like tojjer suggested though means you don't have to reboot between each and can do a nandroid backup. So it's the better option.
