Root Viper 3D rom MMS/3G issues
Akumin
Everything on the phone works great. I can recieve MMS... my 3G is ******ED slow though. idk why like 10kbs idk why it shows 3G this is 1x speeds from back in 1999. Anyone have any info on how to fix the MMS and increase the 3G speeds?
EVO V 4G S-OFF Hboot 1.58
I tried to post on XDA but they are annoying on how new people can't post makes 0 sense.
Thank God! for android forums this site is always helpful and friendly.
I want to point out I'm on Viper software version 1.0.0
Is this a older version I'm running? Cause I look on site and it shows 1.4.1
please let me know Their site is a little hard to find links to download.
I hope it is just a older version.
Oh, I'm sorry... I thought Viper 3D was TEH BEST!!1!
Go ask those DEVs behind that rom, since you think the ones here suck.
Toodles.
Toodles.
There is no need for this SERIOUSLY, this should, nor be how we treat each other, honestly if you don't have nothing nice to say just IGNORE this post and move on" no offence"! To OP I would suggest you do a full wipe again, most of the time it fixs small issues!
I did full wipe I'm running 1.0.0
http://forum.xda-developers.com/showthread.php?t=1671547
on the forum it shows Version 1.4.1
I downloaded to my "Roms" folder full wipe tried to install.... and it fails.
when I try to install it has its own custom launcher and shows Sensation phones to select from the phones are
Sensation Z710e
Sensation 4G
cant remember 3rd one.
I tried the 4G and the Z710E
both fail to install. I dont understand what I am doing wrong and why the install keeps failing.
Sensation Z710e
Sensation 4G
Probably because you're trying to install a Sensation "pyramid" rom on a 3d "shooter" phone. Just a guess. :rolleyes:
Prinny and heythereitsv both have posted guides here on this forum on how to get MMS working on Sense based ROMs.
Do you know which Viper release you are using? I was using R310 but was getting too many reboots.
I am currently using R284 with Anthrax 3.7 and have no trouble with my 3G download speeds. 3D does NOT work on the Viper ROM
Doing the fix will break the rom.
Edit: Prinny's fix does work. I tried to edit the framework with VM settings. That will cause bootloops. Copying the framework he posted does work.
Here's the thing about the fix.
If you do the fix, you need to put the framework-res.apk back into the ROM itself, and re-flash it. No dirty flash, either. Has to be wiped clean totally, then flashed.
I'm using Viper3D with Ziggy kernel clocked to 1.7, and have no issues. Other than 4G not working, but that's a given with this ROM. Same with taking 3D pictures.
Do you think its possible for you to upload your modified viper3d Rom here?? Or is that against the rules even if its only for a lil while??
Well, I can post the drip box link for the modded files. The whole Rom would take forever ;)
Edit:
https://www.dropbox.com/s/f1eh1qluasa55k1/shooter_viper_VM.zip
Really, all you need is the framework-res.apk
Take it out of my zip, and drag it into the ROM zip. Should be /system/framework/framework-res.apk
Just search the zip, if possible. Toss it in the ROM, wipe all, flash, reboot.
Enjoy ;)
Thank you so very much!
did what you said wiped flashed and now MMS outgoing/incoming now works 100%
New Daily Driver for me.
not insulting any other roms by anymeans. BUT! if you like playing GTA with this rom it will play on MAX lag free if you flash Anthrax kernel.
Just a suggestion.
Edit:
Enjoy ;)
Thank you! just comfirm and Mms is fully working thanks!
