Virgin Mobile: 3G Network Dropouts
soundping
My 3G drops out a lot. Sometimes I get a 1x connection.
My old Samsung Intercept didn't seem to have this problem.
So far my 3G and GPS has improved a lot by doing the following.
Try the following steps:
1. Go to --->Settings--->Wireless & Networks---> Wi-Fi (turn off "uncheck", if not already done so). Then exit to main screen.
2. Go to --->Settings---> Location & Security----> Use wireless networks (Turn on "Check"). Then exit to main screen.
By turning on wireless network under Location & Security, your wireless network/wifi connection will not be use. I don't know so do not ask me. lol
Now, you can use SpeedTest Apps to test your connection. I hope it works for you as it did for me. Or maybe my mind is playing trick with me? LOL
Kenster :)
