craig71200
Also, getting Sim card errors... Will repartition work for a new install?
I think he means SD card, not sim card.
Agreed more infop Imation required. Step you took I ROM flashed / steps you took to try and recover.
What are you running disQUOTE]
Latest midnight... With MG2 update from punkmaxx. with original MD7 ROM if i do ##Data# i can see LTE enabled, but as soon as i get the MG2 update its removed.
I tried eveything with no luck... I really appreciate the help though. MG2 and modem failed to write
Mobile Odin seems to be flashing more consistently for some reason. I'll give this another shot tomorrow.
Thanks
