Root [Virgin Mobile] Can't OC
dizmatic
I'm running Victorious and VeaVictus and for some reason I'm stuck at 1.242 even though I have it set at 1.836. Have tried reinstalling the kernel didn't help. Tried both no frills and setcpu both do samething.
Anybody have any id
eas?
Make sure that whatever SuperUser you are using has grated root privileges to the app you are using to change CPU settings. FYI, I use ROM Toolbox Pro with no issues.
Maybe try Conquest ROM and see if that helps. It has both SU and BuzyBox included in the install so it is all set to go!
Also make sure you clear Delvik Cache and cache before flashing ROMs/Kernels :)
Well busybox wasn't installed superuser was. Installed busybox but still no go stuck at 1242.
If you installed busybox installer make sure you run it once to install the binaries you need also. You can also flash victorious again. You wont lose anything. And like buzz said wipe cache and dalvik. I use rom tool box pro as well very good app. Also make sure you check "set at boot" on your settings in overclock app.
