D
Deleted User
Guest
does anyone else's 3g data cut out every 3-5 minutes when on cdma + lte? or is this normal?
You may want to check the APN settings or check the phone settings with *#*#4636#*#* . if those Dont work build.prop edit
Well if you type *#*#INFO#*#* AKA *#*#4636#*#* GO TO THE FIRST ONE SELECT PHONE INFO inside the phone info you need to make sure it say
Lte + CDMA .. If not place on it and back out to the home screen. Do a reboot
