Root [Virgin Mobile] Clean ROM?
bardlehel
Hello. I'm an owner of a Galaxy Victory 4g lte. My carrier is Verizon. I wanted to know if there's a clean ROM I can install (don't care which version of android) that takes out all the verizon software and allows for tethering and hotspot. is there one available?
Thanks
I thought this was a Sprint or Virgin phone. How are you running it on Verizon?
Either way, since it's running Android 4.0, you can disable any bloatware that you want. In each app, there's a way to do it. I'd just be careful on certain stock apps with disabling.
Oops. I meant virgin. My main concedn is having hotspot. I have root but no apps have worked including pdanet+ and couldnt do the entitlement check hack because my settings.db didnt have a settings table
The victorious rom in the Virgin all root section has a rom named victorious. Great rom. The cpu is uncapped which means you can our clock it to anything you want. The gpu is also over clocked. It's a great rom I highly recommend it.
Victorius is a trimmed and optimized version of stock, thats about as clean as it gets.
CM10.x is being worked on, but might take some time.
