Root [Virgin Mobile] HELP I flashed sprint stock rom by accident
Wrenywren
I really need help asap. I accidentally flashed the sprint stock deodexed rooted zip. because I WASNT FREAKING PAYING ATTENTION. Now my phone is stuck in a boot loop and I can't even mount the sd card in twrp and even the backup i made is gone I really dont want to buy a new phone right now. Is there any way to fix this!?
you can probably still put your sd card in your computer and put g60's vm stock backup on it then back in phone.
Did you make sure an unzip the file when moving it to your SD card? Had a little issue at first with switching roms around today and downloaded the stock recovery. I don't think I actually had to use it, but everything works now somehow including MMS, which didn't work at all before.
Do you have a link to the sprint file you flashed?
Now that it's semi-booting, can you run adb logcat on your computer?
If we can figure out which partition is messed up, we have stock backups of all of them available.
Ok false alarm guys my phone finally decided it felt like booting up again and every things back to normal. I will be paying attention to wtf I am doing next time. Thanks for the stupid quick responses with the help. Guys like you are reason the android community is growing. thanks again
