justdoyour
I'm pretty sure you need root for this...
***With this you can't make/receive calls or texts but I use it when I need a really fast connection.***
1. Download an app in play store called "Show Service Mode" - costs a little $
2. Open the app
3. Select the third box to create a shortcut
4. Go back to the main screen and click the new shortcut
5. Select LTE band preference
6. Then select LTE ALL
DONE!!!
7. To switch back to normal open the same shortcut and choose automatic
2. Open the app
DONE!!!
