Chrishuff12345
I'm using CM12 (12.1-20150716-NIGHTLY-d2spr) with this patch and 4GLTE works flawlessly. Everything works including cameras, GPS, SMS, MMS...
I think the only rom that works 100% on the triband model s3 (the one you have) is octos. They have a triband build.
octos for triband sphL710t
I don't have the triband myself, but try asking in the octos thread. Those guys are super helpful. Devs and users alike are all willing to help resolve issues.Ah, I see. Thank you! I'll give this a go now.
*edit*
A few hours in and LTE, is a go! I did have to use Google Messenger for SMS/MMS though, and I've noticed it MMS doesn't work if Wifi is on. Obviously this isn't difficult to work around, but does anybody know of a solution for this? [I'm happy as-is, but if I could avoid having to toggle WiFi for the sake of MMS, that would be nice]
I don't know if anybody has a fix or will reply to this older thread. I just installed the APN fix on my LG Volt from Virgin Mobile and I see the data bars with an exclamation mark next to it. I manually selected APNs and they only work until the phone is rebooted. Then nothing works no matter what I do, need to reflash rom.
is this lollipop? if you haven't already, try this, this is what i have to do on lollipop (ignore what doesn't apply to you but note how the APN fix is applied and rom reflashed w/o reapplying apn fix.)
9. a. Go to "Install Zip", "Choose zip from /storage/sdcard1". Select "cm-12.1-[today's date]-NIGHTLY-d2spr.zip". Click "Yes"
b. When it has finished, go back to your SD card, and do the same with "tk_gapps-stock-5.1.1-[DATE]-signed.zip"
c. Then "Universal_vmu_ApnFix-v.R2.zip"
10. a. Reboot your phone. As soon as it is done booting and optimizing, reboot it back into recovery
b. Flash the CM-12.1 file again
c. Then the gapps-5.1 file, in that order Do not flash the APN Fix again
excerpted from
www.vmroms.com/index.php?topic=882.0a
but i think i've seen that same fix in these forums
Worked on LineageOS 14.1 installed on Galaxy S5 Virgin Mobile version (SM-G900P) when installed per your instructions. Thanks and good work!
It works if you follow my method.
1. Proper wipe
2. Flash ROM, gapps, and apn fix.
3. Boot once to system
4. Boot back to recovery and dirty flash ROM and gapps again (no wipe no APN fix).
5. Profit
