Madbat
Android Expert
Yep.And this will give me 3G and LTE data?
Yeah its a bad zip. Try to extract it, it doesn't extract.I'm unable to flash the -R2 APN fix. Is anyone having this issue? I was trying it out for the 5.1.1 ROM.
I guess it needs to be reuploadedYeah its a bad zip. Try to extract it, it doesn't extract.
Hey MopedRyder , can you reupload it vR2 fix? It's a bad zip file.CURRENT STATUS
***Note - your warranty is now void. If your phone dies, its on you.
This is a continued work in process. This version was built for the universal lte builds most ROM builders have moved to.
Currently we have working 4G LTE with both MMS send and receive working on CM / AOSP ROMs via Hangouts and stock MMS with mooknightus fix. This fix is to achieve 4G/LTE connections. Stock MMS requires the fix by moonknightus (Thanks to him) for the stock MMS fix.
This mod will:
1. Search and edit appropriate lines in build.prop
2. Reset the telephony databases (first boot will take a few)
3. copy + correct apns-conf file
4. Add / update the eri.xml file
Directions:
Flash ROM
Boot up first - reboot recovery
Flash Fix
It may take up to 5min to connect
profit....
Starting with 4.4.4 ROMs I found that you may need to boot first after flash, then go back into recovery and do the fix to take hold.
First boot may take a few minutes to bring up 3G/LTE symbols and get internet connection. The telephony database is being rebuilt - give it a few minutes. If you get an acore type error then try to flash ROM, boot, then flash APN fix.
OFFICIAL CURRENT MOD
Universal LTE builds APN FIX - Version: R2
"Universal_vmu_ApnFix-v.R1.zip"
MD5 of R2 fix:
162FCE4773D279FE37D078F09373AE37
DOWNLOAD HERE
FOR STOCK MMS FIX GO HERE:
http://androidforums.com/virgin-mob...root/865974-aosp-stock-messaging-mms-fix.html
Thanks to moonknightus for the stock MMS fix
FAQ's in the 2nd post.
Folder with all builds here [CLICK]
Special thanks to:
junkie2100
punkmaxx
moonknightus
struckn
It works, I tried the old method of proper wipe, flash rom, gapps, boot phone up, reboot into recovery and flash APN fix to get data. I was surprised Madbat's method works as I'm on AICP 5.1.1.And this will give me 3G and LTE data?
Lost 3G. Tried your method. Is there any way to get 3G back on official CM12.1?Yep.
My 3g works fine. Works on every 5.1.1 ROM. Give it a few minutes to settle, it will work.Lost 3G. Tried your method. Is there any way to get 3G back on official CM12.1?
P.S.: LTE works now...
Its been a couple of hours and still no 3G. I'm going to try it again and see what happens.My 3g works fine. Works on every 5.1.1 ROM. Give it a few minutes to settle, it will work.
Are you trying to switch to 3g? It will do that automatically when you leave a 4g area.Its been a couple of hours and still no 3G. I'm going to try it again and see what happens.
So I can't switch to 3G in Settings?Are you trying to switch to 3g? It will do that automatically when you leave a 4g area.
You should be able to, but why would you?So I can't switch to 3G in Settings?
Idk, it wouldn't work when I tried to switch to 3G.You should be able to, but why would you?
For cm12, do a proper wipe to install new rom. flash ROM, gapps, and APN fix. Boot to system once, then back to recovery and dirty flash ROM and gapps again (no wipe and no APN fix)This adds two new APNs on my CM 12 rom, but I still can't connect to 4G. Any advice?
For some reason that happens to me when I am in a phone call. Data doesn't work in a phone call.I've done this fix bit I still cant get LTE on my stock ROM. Ive tried everything. I look at my 4g properties and there is no network provider or IP address. Please help me.
You should not need this on the stock ROM. It has all the apns already.I've done this fix bit I still cant get LTE on my stock ROM. Ive tried everything. I look at my 4g properties and there is no network provider or IP address. Please help me.
It works if you follow my method.
1. Proper wipe
2. Flash ROM, gapps, and apn fix.
3. Boot once to system
4. Boot back to recovery and dirty flash ROM and gapps again (no wipe no APN fix).
5. Profit
I usually set up first. But I think you can do it right after it completes booting.When you say boot once to system, do you mean reboot after phone set up or reboot after it says aicp is upgrading..installing app 56 of 93?
I think the only rom that works 100% on the triband model s3 (the one you have) is octos. They have a triband build.So, I've been working at this for a few flash's now and I'm getting SMS, 3G, and MMS via Hangouts, but I am unable to get LTE/4G data at all. I've got a SPH-L710T, and my baseband is L710TVPU0AOF2, running Liquidsmooth Lollipop(5.1). I've tried using this flash, and a few others (one of which didn't do anything, the other put the phone into an infinite loop while booting). I've waited for about an hour each flash and still no LTE has appeared (and I'm also confident that 4GLTE is abundantly available in the area). Does anyone have any advice on this?
