moonknightus
I haven't tested any CM build with the new APNs but I'd imagine they may still read as Sprint in the notification drawer/lock screen.
Looks like CM just integrated Boost and Virgin Mobile APNs. Doesn't look like they've integrated the changes necessary to make sending/receiving MMS via the stock Messaging app yet, though.
Check the latest CM Nightly - yeap its there:
<apn carrier="Virgin Mobile" mcc="310" mnc="120" apn="n.vmu.ispsn" user="Sprint" password="*" mmsproxy="68.28.31.7" mmsport="80" mmsc="http://mmsc.vmobl.com:8088/mms?" type="default,supl,mms,fota,dun" />
Win
Hello Merudo! I was excited to see Ting APNs in CM11 M11 but I'm not getting LTE. I documented everything I tried on xda ([ROM][OFFICIAL] CyanogenMod Nightly Builds for d2lte - Post #10313 - XDA Forums).I'm the one who integrated the Boost/Credo/FreedomPop/Ting/Virgin Mobile fixes with CM11. I hope it's working right!
Just bought the Virgin Mobile Galaxy s5. I know kind of mentioned "s5 confirmed workin" but need a double verification....Your telling me that if I download a Sprint ROM "exclude ASOP ROMs for the sake of it" and flash this fix, I should retain %100 functionality with MMS/data...can somebody confirm voicemail too?
The APN fix is for d2lte unified builds. This is so if you flash aosp d2lte builds on a virgin mobile phone you will have data. For MMS there is a fix by moonknightus. As far as I know this is only for s3. To be be clear this is for flashing aosp unified Roms on virgin mobile s3 to get data.
The apn fix does not work with newer versions of Cyanogenmod that have apn info for various carriers programmed in. CM loses LT but the apn fix causes other problems since it has not been updated to work with the latest mods.
I'm not sure if your referring to even newer ones but I'm running cm11 10/11/2014 with the APN fix with zero issues, I never use GPS tho so I can't say on that
For me personally the cm11 when installed will boot and have working data but for me it was continuously cutting in and out repeatedly so I installed the APN fix and it reduced the cut in and out substantially, only issue I notice was sometimes when using WiFi then shutting it off the data won't come back sometimes I'll have to turn it on and off a few times, sometimes I need to reboot, I believe this is something within the ROM tho as I've used mopeds fix on many many builds without issue
Also this fix is flashed meaning it overwrites the APN info with virgin mobiles, I have no idea of any mods that would require this to be updated, only thing I can think of that would require this fix to be updated would be if virgin mobile themselves changed something in the APN info, I'm no expert on this matter tho so its just a guess from someone who had at least something like 100 versions of cm on their S3
Unzip the APN fix and look. There is a little more than just the APN. After you see it you may see what would need to be updated.![]()
Just call 611So i installed cm11 nightlies on my galaxy s3 and for virgin mobile SPH-L70 and the service changed from vrigin mobile to sprint , i activated the phone before i installed the rom, but i only activated , i didn't add service (35$) it was only activated,now I'm not sure if when i top up its going to work since it deleted the virginl mobile app
U must have boost VM devices have only L170 on themI flashed this on my SPH-L170T and now I get no service at all, anyone know how to fix this?
Maybe someone that's more experienced can help u then cus I don't have this device I heard somebody else here had the same issue maybe APN settings zip for boost will work that wat ppl said I follow this forums all day long ur device is tri band from wat I heard ur device is a boost device VM boost all sprints towersI recently ordered a new phone because my last one was damaged. My old phone was a L170 this one is a L170T. I am 100% sure this is a virgin mobile phone
