jamesh0317
Thanks! I have the mk5 modem. After flashing I have LTE when I should, the pulldown identifies "Virgin Mobile" and I can send and recieve MMS in both the stock CM11 messenger and Handcent.
EDIT: I can only send in the stock messenger app. I can send and receive in Handcent.
I am hoping that someone can help me with a build question. I would like to incorporate these fixes into my CM11 nightly builds so I don't have to flash both the ROM and the fix when I update the ROM. As far as I can tell I just need to replace the
/system/build.prop
/system/etc/apns-conf.xml
/data/eri.xml
with the ones from this zipfile prior to building. I planned on doing this with a script to do the following after I repo sync:
mv ~/staticfiles/build.prop ~/android/system/out/target/product/d2lte/system/build.prop
mv ~/staticfiles/apns-conf.xml ~/android/system/out/target/product/d2lte/system/etc/apns-conf.xml
mv ~/staticfiles/eri.xml ~/android/system/out/target/product/d2lte/data/eri.xml
brunch d2lte
However- there is no "eri.xml" in ~/android/system/out/target/product/d2lte/data. and if I 'find -name eri.xml' in the ~/android/system directory there are many directories that contain eri.xml, even in ~/android/system/out/.
I believe that this file only serves to make it say "Virgin Mobile" rather than "Sprint" in the pulldown, but I like that.
So, the question is: Where is the eri.xml that I need to replace prior to building CM11?
Thanks again, and hopefully this isn't a thread hijack. That was not the intent.
/system/build.prop
/data/eri.xml
brunch d2lte
Seems to work great for me...
