insanelycool
I read a bit about this in another part of the forum about APNs and whatnot.
I found out the other day that I can't send or recieve MMS... I tried the method of GoSMS and manual APN settings, but it only worked when I switched the phone to CDMA only mode.
Does anyone know if this is supposed to work for 4g (LTE/CDMA mode)?
When I called tech support they said that CA and Washington DC (Where I am located) are having issues with MMS.
Is there a workaround I can use so I don't have to switch to CDMA mode to do MMS? Maybe an app that forces a 3g connection temporarily?
I manually browsed to the "apns-conf.xml" file in system/ect and looked at it, all the setting are the sprint APN's... My service works great 4g connection, ect, just no MMS... I've even managed to get about 10GB of data this month with no apparent throttling the whole time. I may just be lucky or on a tower with little usage other than myself.
Any help would be appreciated... I don't really want to trade the phone in like the post I read suggested. I have no splash screens other than the samsung one at boot.
