Root [Virgin Mobile] [OLD]Sprint to Virgin Mobile LTE/MMS FIX [OLD]
Rate how the mods worked for you
  • AOSP Version 1 worked (LTE / 3G / MMS / Internet)
    Votes: 0 0.0%
  • AOSP Version 1 partially worked
    Votes: 0 0.0%
  • AOSP Version 2 partially worked
    Votes: 0 0.0%
  • TW Version 1 partially worked
    Votes: 0 0.0%
  • Total voters
    20
With touchwiz roms after flashing the kernel do we have to wipe cashe davik an do fix permissions?
An do we need to flash sprint firmware ??
does anyone know if hyperdrive rom works?
if its 4.3 or 4.2.2 rom?
i would like the feel of samsung galaxy s4 rom onto s3 <3
i found touchwiz 5x6.zip i dont know how to upload on here but yea lol
Hyperdrive is a 4.2.1 TW ROM. Ive used it.
Good news hyper drive tomorrow is successfully working I just
Wipe data/ system
Cache and device cache
Install hyper drive rls15 latest update I think
And then flash tw.apn mod. *thanks* feeling good with hyper drive rom
Wifi works and 3G and mms when you flash tw mod give it sec you get update and don't worry it goes back to 3g I'm going to see if 4g works when I'm about to leave to work.
After flashing any kernel or any ROM I would say its a good idea to wipe cache and dalvik / fix perm.
Ive never flashed any print firmware - but it takes me more steps at time to get stuff to flash.
Wipe data/ system
Thanks Ill show TW (version2?) mod works with Hyperdrive.
I have hyper drive 4.12 ?
To find out just what version of android you are on just extract all the files from the zipped rom. Then navigate to its system folder. Open the build.prop file with a text editor (I use Notepad++)
Toward the top look for the line:
ro.build.version.release=4.3
This is from a CM10.2 build. Its Android 4.3
Im got the HyperDrive RLS15 (not sure it its latest) but its listed as:
ro.build.version.release=4.1.2
Its Android version 4.2.1
I'll take a look at it later if it is 4.2.1
It say on 4.1.2 it works good test call I think you might hear little echo or I might boost up the volume calling but the "activate this device" isn't working which you see sprint symbol doesn't work. Carrier status is nothing lol but yeah
4g and everything?
Good question. I don't live in a 4g area so I'm relying on testers to tell me.
That said I'm trying to get CM / AOSP /And TW ROMs to all have working 3G and MMS first, then on to 4G.
By the looks of it I have a good TW fix. I'll need AOSP confirmed working then on to the beast CM.
As for CM and AOSP I'm working exclusively on Android 4.3. If it works on 4.2 then that's great too
Also additional reminder :
It may take up to 10 to 15 min for Internet to connect. Its normal. My flash erases the telephone database and it may take time to rebuild. First boot with fix I'd keep WiFi off to force it.
I understand that you're working to get 3g and mms working first, I was just asking peter counias if by any chance 4g was working on wicked sensations.
I can't wait to get a fully functional non-touchwiz rom! Keep up the good work!!!
3g works already thats a given. working on mms and 4g but there may be other components involved as well
Unfortunately that doesn't seem to be the case for us (me?) on CM10.2
When I loaded that up no Internet or 3G, not even after any fixes I've tried. It may be confined to just 10.2. Funny the AOSP fix I posted worked fine on those ROMs but failed on CM10.2.
That's why the make sure 3G works statement.
Thanks! Yea for all but CM 3G is a given. I'd love something like a list of folks in LTE areas that could do some testing.
This is still a rather small group still, but growing.
I live in a 4g area and would be happy to do some testing for you in about a week and a half. I'm a college student and I've got 4 exams coming up so I don't have a lot of time right now. If you really need something specific tested before then let me know and I can probably make it happen.
Finally just upgraded to a 32gb microSD so I can do some more testing. I live in a 4G area so can know immediately after flashing if 4G is working. Right now i'm back on rooted stock rom but would love to get a working 4G CM or MOAR rom for daily use. Lemme know what I can do.
Why not try (test) the newest v6 of MOAR. Its a prerelease:
xda-developers - View Single Post - [ROM] [MOAR] [MD4] v6.0 Preview Post #10328 / AweSomeSauce / Crazy Modz [09.23.13]
Try the version 2 TW mod in my OP and report back please.
Thanks - you are on my list! Just holler when you can.
CM APN Fix posted. I tested it on CM10.2 and also PACMAN4.3-Build-1 (both Android 4.3)
I may be able to combine CM and AOSP but for now - I need sleep.
Please test and report back with:
ROM
MMS Working?
LTE Working?
Calls working?
Internet Working?
This fix may take up to 15min to connect to internet - give it time. Shut down you wifi at first boot to force the phone to connect via 3G / LTE.
