Posted new nightly for January 11, 2014!
Created from the auto patcher I coded
anyone know if we ave themes for this?.. i'd like my status bar icons blue...
GravityBox should be able to do it.
Thanks I'm using handset
Is there any way to remove the asserts from my phone?
I'm trying to install the nightly updates from cyanogen updater in the phone settings, but they fail to install unless I remove the asserts which I'm having to do from the pc. I would like a more convenient way to keep up with the nightlies.As long as you have a l710 with virgin mobile you won't need to edit anything for this, eb has already done and it
As for you question, no, the asserts in the phone are basically a line that says this is a sprint, VM or whatever phone, the reason editing is required at all is because most Roms built for this device are built for the sprint version which is identical to ours, so we edit the sprint lines out and make the VM lines, or remove them altogether
But in this particular forum there are already at least I believe 2-3 Roms which don't require you to edit anything
