pOsSuM72
YesIf I flash the latest nightly cm11 d2lte version, which is 20150105, would I also have to flash an apn fix? I had just recently gotten this phone and it is build NF4.
NF4 is the tri-band model. So I think there are other steps, if it works at all.If I flash the latest nightly cm11 d2lte version, which is 20150105, would I also have to flash an apn fix? I had just recently gotten this phone and it is build NF4.
Oops I didn't see that.There's only a few that will just have to try.Can't remember if I tried this build or not.NF4 is the tri-band model. So I think there are other steps, if it works at all.
It does work but, camera and rotation is messed up.You can use adaptive rotation from the playstore for that fix.The camera, I tried a few different ones and no luck.If I flash the latest nightly cm11 d2lte version, which is 20150105, would I also have to flash an apn fix? I had just recently gotten this phone and it is build NF4.
I haven't tried it but most likely wont, baseband will say unknown but all ya can do is give it a try and see.Thank you. Do you know if the latest Carbon Rom nightly would work on this SPH-L710T NF4 device? Would all d2lte roms have the rotation and camera issues on this device?
